[mapguide-internals] MGOS Live CD
Sylvain Pasche sylvain.pasche at camptocamp.com
Wed Aug 13 06:26:31 EDT 2008
Zac Spitzer wrote:
>> 1) The easy but ugly one: we build mapguid from the Unix instructions
>> and create a single mapguide.rpm package with all the files that have
>> been installed inside /usr/local/mapguideopensource/ (and init.d script
>> files for starting the service).
> I would love to see that script, how easy is it?
I don't have such a script. It should be a .spec file that launches the
build scripts in the %build section and then references all the
installed files in /usr/local/mapguideopensource in the %files sections
(if I remember correctly how to build rpms).
>> 2) The more complex and clean solution:
>> Create rpm files for each of the mapguide dependencies (or use the
>> existing .rpm files for libraries already available in the
>> distribution). I identified the following dependencies:
> sounds like a great idea, it would also indirectly help building as it
> seems people
> are getting stuck with missing dependancies
> FDO itself should be a rpm
yes, that could be useful for using it without Mapguide (and should be
installed in /usr/lib like all libraries).
Sylvain
More information about the mapguide-internals mailing list
