[mapguide-internals] MGOS Live CD
Zac Spitzer
zac.spitzer at gmail.com
Wed Aug 13 06:03:30 EDT 2008
On Wed, Aug 13, 2008 at 7:35 PM, Sylvain Pasche
<sylvain.pasche at camptocamp.com> wrote:
> Hi Zac,
> I would say it depends ;-)
> I see two possibilities.
> 1) The easy but ugly one: we build mapguid from the Unix instructions
> and create a single mapguide.rpm package with all the files that have
> been installed inside /usr/local/mapguideopensource/ (and init.d script
> files for starting the service).
I would love to see that script, how easy is it?
> 2) The more complex and clean solution:
> Create rpm files for each of the mapguide dependencies (or use the
> existing .rpm files for libraries already available in the
> distribution). I identified the following dependencies:
sounds like a great idea, it would also indirectly help building as it
seems people
are getting stuck with missing dependancies
FDO itself should be a rpm
> FDO (3.3.1):
> Third party:
> xerces-c 2.5.0
> xalan-c 1.7.0
> cppunit 1.9.0
> sqlite 3.3.13
> boost 1.34.0
> curl 7.16.4
> openssl 0.9.8e
> gdal 1.4.3
> Other:
> TODO
> MapGuide (2.0.1):
> APT:
> apache 2.2.4
> php 5.2.5
> tomcat-connector (optional) 1.2.25
> OEM:
> ACE 5.4
> DWFCORE 1.0
> DWFTOOLKIT 7.1
> DWFEMAP 1.0
> GEOS 2.2.0
> PHP 5.2.5
> SWIGEx 1.0
> BDBXML 2.3.10
> Depends on:
> Berkeley DB 4.5.20:
> xquilla 1.0.1
> xerces-c 2.7.0
> CPPUNIT 1.9.14
> IMake 1.0
> GDAL 1.4.4
> PROJ 4.5.0
> ZLIB 1.2.3
> LIBPNG 1.2.8
> JPEG 6b
> FREETYPE 2.1.10
> GD 2.0.33
> AGG 2.4
> JSONcpp (version?)
> Other:
> TODO
> Sylvain
> Zac Spitzer wrote:
>> How hard would it be to produce rpm's for MGOS ?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals
