[mapguide-internals] MGOS Live CD
Sylvain Pasche
sylvain.pasche at camptocamp.com
Wed Aug 13 05:35:11 EDT 2008
Hi Zac,
I would say it depends ;-)
I see two possibilities.
1) The easy but ugly one: we build mapguid from the Unix instructions
and create a single mapguide.rpm package with all the files that have
been installed inside /usr/local/mapguideopensource/ (and init.d script
files for starting the service).
2) The more complex and clean solution:
Create rpm files for each of the mapguide dependencies (or use the
existing .rpm files for libraries already available in the
distribution). I identified the following dependencies:
FDO (3.3.1):
Third party:
xerces-c 2.5.0
xalan-c 1.7.0
cppunit 1.9.0
sqlite 3.3.13
boost 1.34.0
curl 7.16.4
openssl 0.9.8e
gdal 1.4.3
Other:
TODO
MapGuide (2.0.1):
APT:
apache 2.2.4
php 5.2.5
tomcat-connector (optional) 1.2.25
OEM:
ACE 5.4
DWFCORE 1.0
DWFTOOLKIT 7.1
DWFEMAP 1.0
GEOS 2.2.0
PHP 5.2.5
SWIGEx 1.0
BDBXML 2.3.10
Depends on:
Berkeley DB 4.5.20:
xquilla 1.0.1
xerces-c 2.7.0
CPPUNIT 1.9.14
IMake 1.0
GDAL 1.4.4
PROJ 4.5.0
ZLIB 1.2.3
LIBPNG 1.2.8
JPEG 6b
FREETYPE 2.1.10
GD 2.0.33
AGG 2.4
JSONcpp (version?)
Other:
TODO
Sylvain
Zac Spitzer wrote:
> How hard would it be to produce rpm's for MGOS ?
More information about the mapguide-internals
