[mapguide-internals] RFC 53 caching is gooo but how do you flush
the schema cache
Zac Spitzer
zac.spitzer at gmail.com
Thu Aug 14 12:31:08 EDT 2008
the problem is when you create a new table in oracle, it won't appear in the
schema until it expires
On Fri, Aug 15, 2008 at 2:25 AM, Steve Dang <steve.dang at autodesk.com> wrote:
> No, this does not.
> When debugging, you need to increase the connection / session timeout so that it takes your debugging time into account. Otherwise, the FDO connection / schema cache item will get expired and flushed before you finish your debugging session.
> Steve.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Wednesday, August 13, 2008 9:46 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC 53 caching is gooo but how do you flush the schema cache
> I know about the expiry, it's one of those strange things with
> mapguide when your programming,
> often when you are debugging etc, the provider will of expired since
> you last ran your code and
> it magically works until you start testing
> Does this fall under the scope of RFC 53?
> z
> On Thu, Aug 14, 2008 at 1:33 PM, Steve Dang <steve.dang at autodesk.com> wrote:
>> No, we will need to add a new API for that. Note that an FDO connection / schema cache item will also be automatically flushed when it is expired.
>> Steve.
>> ________________________________________
>> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
>> Sent: Wednesday, August 13, 2008 08:50 PM
>> Subject: [mapguide-internals] RFC 53 caching is gooo but how do you flush the schema cache
>> Is it possible to add the ability to flush the schema cache for a fdo connection
>> so far the only way i have found to do it is a server restart or
>> touching the feature source
>> z
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
