[mapguide-internals] Error in login.php
Bruce Dechant bruce.dechant at autodesk.com
Thu Aug 21 15:12:09 EDT 2008
The failed coordinate system unit tests are all EPSG related.
Can you check to see that your categories.txt file contains an entry for epsg? Please also check that there is a corresponding filename that matches this entry and it is located in the PROJ4 environment variable PROJ_LIB - this should be point to the PROJ4 nad folder. Also please check that the GDAL_DATA environment variable points to the GDAL data folder.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of sergi nistal
Sent: Thursday, August 21, 2008 12:48 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Error in login.php
Thank you, I've solved both problems with the login. But, the issue of failures CoordinateSystem test, how are they important? I'm working with php and apache server.
> From: tom.fukushima at autodesk.com
> To: mapguide-internals at lists.osgeo.org
> Date: Thu, 21 Aug 2008 10:56:28 -0700
> If I look at my MapGuide install, the php_MapGuideApid.dll file should copied to the Php/ext directory.  Also, note that the php directory looks to have a lot of MapGuide DLLs in it; you should make sure to have those there as well.
> Unfortunately, unless someone can point me to it, our documentation on how to get the web tier running from scratch on Windows is pretty poor.  If you follow the technique in http://wiki.osgeo.org/wiki/Building_MapGuide_on_Windows which seems to base things on having an already installed server and web tier (tough on Vista, but possible if you follow the steps in http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7) then you might be able to get up and running more quickly.
> However, if you could generate some documentation of how to get the web tier up and running when compiling from source on Windows, that would be fantastic!  I think that this information could go here: http://wiki.osgeo.org/wiki/Building_MapGuide_on_Windows.
> Thanks
> Tom
> nistal
> Sent: Thursday, August 21, 2008 11:42 AM
> Hi,
> I´ve made a manual install (source code) in debug mode. The version of mapguide is 2.0.1 on Windows Vista and FDO version is 3.3.1. I´m following the guide 'Building MapGuide on Windows' and I´m in step 'Testing the Site Administrator' ('Verifying the Configuration') and in step 'Testing the Web Server Extensions'. The php_MapGuideApid.dll is in C:\MAPGUIDE2\mapguide-2.0.1\Web\bin\debug. Do I have to move the library elsewhere?
> Another thing; in the next step ('Running Test Suites') all test are OK except the first (test CoordinateSystem), there are 7 failures. See attach images.
> Thanks for all.
> > Date: Thu, 21 Aug 2008 23:12:29 +1000
> > From: zac.spitzer at gmail.com
> > Subject: Re: [mapguide-internals] Error in login.php
> > Did you do a standard install? which options did you choose?
> > Looks like the web tier can't access php_MapGuideApi.dll
> > z
> > On Thu, Aug 21, 2008 at 10:50 PM, sergi nistal <serginistal at hotmail.com> wrote:
> > > I have that two erros:
> > >  Error in the step 'Testing the Site Administrator'
> > >     http://localhost/mapguide/mapadmin/login.php
> > >         Fatal error: Call to undefined function
> > > MgInitializeWebTier() in
> > > C:\MAPGUIDE2\mapguide-2.0.1\Web\src\mapadmin\login.php on line 70
> > >  Error in step 'Testing the Web Server Extensions'
> > > http://localhost/mapguide/mapviewerajax/ajaxviewer.php/?WEBLAYOUT=
> > > Library://ATest.WebLayout
> > > SetLocalizedFilesPath() in
> > > C:\MAPGUIDE2\mapguide-2.0.1\Web\src\mapviewerphp\mainframe.php on
> > > line 39
> > > Thanks
> > > _________________________________________________________________
> > > ¡Lo mejor de MSN y Windows Live en tu móvil! Hotmail, Messenger,
> > > Spaces... Pruébalo ya  y disfruta de todas sus ventajas donde
> > > quieras
> > > http://serviciosmoviles.es.msn.com/_______________________________
> > > ________________
> > > mapguide-internals mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> > Zac Spitzer -
> > http://zacster.blogspot.com (My Blog)
> > +61 405 847 168
> ¿Preparándote para el verano? En Windows Live Search encontrarás las
> mejores dietas para conseguir tu peso ideal
> http://search.live.com/results.aspx?q=dieta&form=MKTPG
Nuevo Canal Messenger
http://www.vivelive.com/ilovemessenger/
More information about the mapguide-internals mailing list
