[mapguide-internals] RFC 49 parameter logging delimiters tweak
Zac Spitzer
zac.spitzer at gmail.com
Sat Dec 27 00:53:50 EST 2008
Currently the delimiters for the parameters use a comma as the
delimiter between the options,
it makes parsing the parameters harder than neccesary as there are
often commas in the WKT
Resource=Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource,ClassName=SDF_2_Schema:VotingDistricts,Options={{Operator=1}{GeomProp=Data}{GeomOp=10}{Geometry=POLYGON
((-87.783866628374042 43.691398128787803, -87.676641873488435
43.691398128787803, -87.676641873488435 43.797520000480297,
-87.783866628374042 43.797520000480297, -87.783866628374042
43.691398128787803))}}
Would it make sense to use a semi-colon instead, just to make parsing
this easier?
I am writing a up little php script which parses the Trace.log and
re-executes the
query for performance profiling
Enhancing the END entries by adding the BGN parameters and elapsed time, maybe
as level 4 would make the log files useful without pre-processing
z
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
