[mapguide-internals] improving the default php configuration
Zac Spitzer zac.spitzer at gmail.com
Wed Dec 17 02:05:05 EST 2008
the logging option sounds like the right way to go, what are you going
to call the log file?
I updated http://trac.osgeo.org/mapguide/wiki/Debugging to explain
about enabling php display errors
On Wed, Dec 17, 2008 at 5:56 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> I wouldn't be adverse to changing PHP to log to the MapGuide logs directory.  I really don't think that setting display_errors to on is a good idea; I'd prefer to see _more_ secure by default rather than less.
> Of course, if you're interesting in helping to build the installer, anything is possible ;)
> Jason
> ________________________________
> From: Zac Spitzer
> Subject: [mapguide-internals] improving the default php configuration
> There seem to be a number of common issues with php and mapguide,
> the current default config for php.ini is as follows
> line 632: display_errors = Off
> line 408: ;error_log = filename
> this combination results in a effective silent php fail with errors
> not being shown or logged
> there is the additional problem of multiple php's in the path but that
> seems to of been addressed with
> http://trac.osgeo.org/mapguide/ticket/657
> would it be worth tweaking these values?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
