[mapguide-internals] MGOS v1.2 Service Issues
nclayton
nclayton at gmail.com
Thu Feb 21 12:15:25 EST 2008
Hi all,
I finally made all the changes that I needed to make and have pushed MGOS
out to our production server (which has the exact same configuration as the
dev server, except with better specs) and now the service is bombing out at
random intervals.
Here's what is happening:
I connect to the production server through remote desktop so I don't have to
go to the server room. When I do go into the server room, I see that the
Microsoft Script Debugger is open. I do not see this on my session through
remote desktop, so I am not sure when this pops up or why. Also, there are a
few events logged when the service goes down:
Application:
MapGuide Server v1.2
Event ID: 0
Time: 9:53:24 AM
The description for Event ID (0) in Source (MapGuide Server v1.2) cannot be
found. The local computer may not have the necesary registry information or
message dll files to display messages from a remote computer. You may be
able to use the /AUXSOURCE=flag to retrieve this description; see Help and
Support for details. The following information is part of the event: Server
stopped.
Repeated at 9:53:29 AM with:
The following information is part of the event: Server starting...
The following information is part of the event: Server started...
System:
Service Control Manager
Event ID: 7035
Time: 9:53:24 AM
The MapGuide Server v1.2 service was successfully sent a stop control.
Application Popup
Event ID: 26
Time: 9:53:24 AM
Application popup: MgServer.exe - Application Error: The instruction at
"0x7c82f527" referenced memory at "0x1562e4c5". The memory could not be
"read"
Click on OK to terminate the program
Event ID: 7036
Time: 9:53:24 AM
The MapGuide Server v1.2 service entered the stopped state.
Event ID: 7036
Time: 9:53:26 AM
The MapGuide Server v1.2 service entered the running state.
Event ID: 7035
Time: 9:53:24 AM
The MapGuide Server v1.2 service was successfully sent a start control.
I tried setting the service to restart on failure, but that causes a
communication error between the viewer and the server. I had to manually
tell it to restart before the viewer would work properly again.
Hopefully someone else has seen this and has an idea of what can be causing
it.
View this message in context: http://www.nabble.com/MGOS-v1.2-Service-Issues-tp15613803s16610p15613803.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
