[mapguide-internals] PATCH: Fix for #163 (WebStudio HasLayer and Map Preview Dependancy on 'mapviewerphp' Option)
Jackie Ng jackie.ng at aecsystems.com.au
Mon Jan 7 17:14:54 EST 2008
That's strange, my outbox showed the diff was attached (??)
I'll post the patch on trac, later today.
- Jackie
JasonBirch wrote:
> Or attach it as a .patch file to the Trac ticket?  This provides syntax
> highlighting, etc, and explicitly links the fix to the problem.
> Jason
> -----Original Message-----
> From: Bruce Dechant
> Subject: RE: [mapguide-internals] Re: PATCH: Fix for #163 (WebStudio
> I think your attachment was automatically removed.
> Could you reply with the SVN difference (the contents of the patch
> file)?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://www.nabble.com/PATCH%3A-Fix-for--163-%28WebStudio-Has-Layer-and-Map-Preview-Dependancy-on-%27mapviewerphp%27-Option%29-tp14552718s16610p14677415.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
