[mapguide-internals] Dynamic tile rendering proposal
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jul 31 10:12:32 EDT 2008
That might get what I want, assuming that WMS actually handles the
splitting correctly.
But that would also remove any possibility to work with the runtime map,
which is required
to handle selections, so unfortunately that does not work.
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> How does exposing mapDefinition's as WMS sound as a solution?
> On Thu, Jul 31, 2008 at 11:02 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> As I understand meta tiling, it works by creating a larger image than the
>> one requested (smaller),
>> in anticipation of requests to similar/adjacent (smaller) images.
>> In a sense, that is what I want, but I would request the larger image, and
>> retrieve the sub-tiles.
>> Unlike meta-tiling, the purpose of this feature is not to create extra data
>> in advance,
>> but rather serve a large image in smaller chunks.
>> If the server renders the entire image and just hands out the smaller
>> images, I would not
>> expect the percieved transmission time to diminish, as the crucial part is
>> the time that goes
>> before the initial image is displayed.
>> From a users perspective, a long but visible progress, is better than a
>> shorter uncertain wait.
>> (Within certain bounds of course)
>> Zac Spitzer skrev:
>>> Kenneth, do you think meta tiling could also solve this problem?
>>> On Thu, Jul 31, 2008 at 7:20 PM, Kenneth Skovhede, GEOGRAF A/S
>>>> The current tile mechanism is using static images to serve pre-built
>>>> images
>>>> as tiles.
>>>> For this reason, the tiles are only usefull with "base layers".
>>>> I have worked with OpenLayers, and it has a very nice tiling mechanism.
>>>> DM Solutions have built some tiling support into the MapGuide provider
>>>> for
>>>> OpenLayers.
>>>> This uses the static tiles, and the row/column index system in MapGuide.
>>>> Using the "original" OpenLayers tiling mechanism one can get a dynamic
>>>> MapGuide image
>>>> to load as tiles, giving the illusion that the page loads faster (when it
>>>> actually loads a bit slower).
>>>> The problem with this method is that MapGuide optimizes the rendered
>>>> image
>>>> for the given bounds.
>>>> This is especially true for calculating label positions and overlaps.
>>>> I would like to add a parameter for the "GETMAPIMAGE" call that accepts
>>>> an
>>>> "outer bounds" parameter.
>>>> With this parameter, MapGuide should render the extent given by the
>>>> extent
>>>> parameter, but use the outer
>>>> bounds for determining label placements and any other details that may
>>>> have
>>>> the same problems.
>>>> With this, it would be possible for MapGuide to serve tiles from
>>>> MapGuide,
>>>> without relying on a
>>>> static tilcache.
>>>> I would like to add this as an RFC, but would like feedback on the idea,
>>>> as
>>>> well as possible problems.
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> mapguide-internals at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
