[mapguide-internals] Dynamic tile rendering proposal
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 31 10:46:39 EDT 2008
So like the GETILEIMAGE result via the GETMAPIMAGE parameters?
On Fri, Aug 1, 2008 at 12:12 AM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> That might get what I want, assuming that WMS actually handles the splitting
> correctly.
> But that would also remove any possibility to work with the runtime map,
> which is required
> to handle selections, so unfortunately that does not work.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Zac Spitzer skrev:
>> How does exposing mapDefinition's as WMS sound as a solution?
>> On Thu, Jul 31, 2008 at 11:02 PM, Kenneth Skovhede, GEOGRAF A/S
>>> As I understand meta tiling, it works by creating a larger image than the
>>> one requested (smaller),
>>> in anticipation of requests to similar/adjacent (smaller) images.
>>> In a sense, that is what I want, but I would request the larger image,
>>> and
>>> retrieve the sub-tiles.
>>> Unlike meta-tiling, the purpose of this feature is not to create extra
>>> data
>>> in advance,
>>> but rather serve a large image in smaller chunks.
>>> If the server renders the entire image and just hands out the smaller
>>> images, I would not
>>> expect the percieved transmission time to diminish, as the crucial part
>>> is
>>> the time that goes
>>> before the initial image is displayed.
>>> From a users perspective, a long but visible progress, is better than a
>>> shorter uncertain wait.
>>> (Within certain bounds of course)
>>> Zac Spitzer skrev:
>>>> Kenneth, do you think meta tiling could also solve this problem?
>>>> On Thu, Jul 31, 2008 at 7:20 PM, Kenneth Skovhede, GEOGRAF A/S
>>>>> The current tile mechanism is using static images to serve pre-built
>>>>> images
>>>>> as tiles.
>>>>> For this reason, the tiles are only usefull with "base layers".
>>>>> I have worked with OpenLayers, and it has a very nice tiling mechanism.
>>>>> DM Solutions have built some tiling support into the MapGuide provider
>>>>> for
>>>>> OpenLayers.
>>>>> This uses the static tiles, and the row/column index system in
>>>>> MapGuide.
>>>>> Using the "original" OpenLayers tiling mechanism one can get a dynamic
>>>>> MapGuide image
>>>>> to load as tiles, giving the illusion that the page loads faster (when
>>>>> it
>>>>> actually loads a bit slower).
>>>>> The problem with this method is that MapGuide optimizes the rendered
>>>>> image
>>>>> for the given bounds.
>>>>> This is especially true for calculating label positions and overlaps.
>>>>> I would like to add a parameter for the "GETMAPIMAGE" call that accepts
>>>>> an
>>>>> "outer bounds" parameter.
>>>>> With this parameter, MapGuide should render the extent given by the
>>>>> extent
>>>>> parameter, but use the outer
>>>>> bounds for determining label placements and any other details that may
>>>>> have
>>>>> the same problems.
>>>>> With this, it would be possible for MapGuide to serve tiles from
>>>>> MapGuide,
>>>>> without relying on a
>>>>> static tilcache.
>>>>> I would like to add this as an RFC, but would like feedback on the
>>>>> idea,
>>>>> as
>>>>> well as possible problems.
>>>>> _______________________________________________
>>>>> mapguide-internals mailing list
>>>>> mapguide-internals at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the mapguide-internals mailing list
