[mapguide-internals] MGOS 2.0.1 status
Tom Fukushima
tom.fukushima at autodesk.com
Fri May 2 12:19:01 EDT 2008
OK, it sounds like there are some Fusion fixes that we would like to get into 2.0.1. Do you have an ETA on when they will be in?
As for the other 2.0.1 changes, unless someone sees otherwise, I don't see anything that will require an RC.
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Friday, May 02, 2008 7:37 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MGOS 2.0.1 status
I was sort of planning to fix the misalignment bug as part of some
refactoring work I'm doing to allow more than one map in a MapGroup (and
allow other types of layers to be used). That work should definitely be
targeted to a 1.1 release but it sounds like I should do a patch for the
mis-alignment issue before that. I know what the problem is and don't
think it would involve too much time.
Mike
Paul Spencer wrote:
> I think some of the new changes in Fusion recently are destined for a
> 1.1 release rather than a 1.0.5 release because they are new features
> rather than bug fixes. I will talk to Mike early next week about the
> state of the 1.0 branch vs trunk and try to bring over any important
> bug fixes. As Zac mentioned, the misalignment of the tiles seems like
> an important fix to get in, I'm not sure of the status of that.
> For a potential 1.1, I think we have a few more things to go in
> including some Jx work to factor out Prototype/Scriptaculous in favour
> of mootools.
> Cheers
> Paul
> On 1-May-08, at 11:01 PM, Jason Birch wrote:
>> To follow up to myself....
>> As long as we take the Fusion that is in trunk, I think we're good
>> for all the fixes up to 1.0.4, which is the most current release.
>> There were some revisions between the revision used for MapGuide
>> trunk and the 1.0.4 release, but I think that was all SVN migration
>> stuff.
>> There are certainly some other outstanding bugs in Fusion, but 1.0.5
>> appears to be a ways out. Fortunately, fusion is relatively easy to
>> upgrade (at least between point releases).
>> Jason
>> ________________________________
>> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Jason
>> Birch
>> Sent: Thu 2008-05-01 4:25 PM
>> Subject: RE: [mapguide-internals] MGOS 2.0.1 status
>> That sounds great.
>> Is there an updated Fusion for this build compared to 2.0? I believe
>> that some significant bugs have been fixed since the 2.0 release, in
>> selection and maybe in some of the canvas tools (select radius, distance
>> measure, etc).
>> Will we have an internal-only RC for this release, or are the changes
>> small enough that you're comfortable with an untested point release?
>> Jason
>> From: Tom Fukushima
>> Subject: [mapguide-internals] MGOS 2.0.1 status
>> Here's a status update on MGOS 2.0.1. I was waiting to get merge
>> modules for the missing providers, but it doesn't look like that is
>> going to happen for the already released FDO binaries (we will have them
>> in future builds though). So now we're trying to figure out which
>> version of FDO to install and once we have that I should be able to post
>> a MGOS 2.0.1. This should all be resolved within a few days I hope.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://www.dmsolutions.ca/
More information about the mapguide-internals
