[mapguide-internals] MGOS 2.0.1 status
Tom Fukushima tom.fukushima at autodesk.com
Mon May 12 18:16:26 EDT 2008
Yes, I'm sure that we could wait for more fixes, and then in the mean time find more problems that we would like to fix and wait some more, and then find more problems and then wait some more.
Jason, are you using the Fusion trunk or the 1.0 branch?  We are using the 1.0 branch so if you're using trunk that will not be useful for us anyway.  If you are using the branch, I remember seeing a pretty serious problem with an error dialog about units coming up, are you not seeing that?
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, May 12, 2008 3:34 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MGOS 2.0.1 status
I believe that the version that came with 2.0.0 had considerable
defects, even when compared to what's in the MapGuide SVN.  I'm not
going to be able to do reasonable testing of 2.0.1 without grafting a
later release of Fusion into it, which I think pretty-much invalidates
my testing.
I understand the pressures on your resources, but am disappointed that
we couldn't get a working Fusion into 2.0.1.
Jason
It has the same version of Fusion that was in 2.0.0.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
