[mapguide-internals] MGOS 2.0.1 status
Tom Fukushima
tom.fukushima at autodesk.com
Wed May 14 10:45:47 EDT 2008
Not sure what you are asking for, but our build person is not available so unfortunately we can't make any changes.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, May 13, 2008 11:36 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MGOS 2.0.1 status
is it possible for the linux tarballs to include (or to provide
another one) which is checked out and includes the subversion tags?
On Wed, May 14, 2008 at 3:10 PM, Tom Fukushima
<tom.fukushima at autodesk.com> wrote:
> Thanks Zac,
> We've got the Fusion update in, so we are building with that tonight. If all goes well, I will post that build as 2.0.1.
> Tom
> Sent: Tuesday, May 13, 2008 8:37 PM
> Some feedback from my cartographer,
> "rendering with heavy data is much better and it's its showing up
> exactly as i want rather than doing its own thing"
> z
> On Wed, May 14, 2008 at 12:20 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> > I just installed 2.0.1 on windows and then updated fusion to the
> > http://svn.osgeo.org/fusion/tags/fusion-1.0.6/ and it's all working
> > brilliantly :)
> > Tiled maps in fusion are reporting the correct co-ordinates in both FF2 & IE7
> > You will need to uninstall mapguide 2.0 first to test this build
> > Testing continues...
> > z
> > On Wed, May 14, 2008 at 1:49 AM, Chris Claydon
> > <chris.claydon at autodesk.com> wrote:
> >> I should be able to do it from here.
> >> Chris.
> >> From: Tom Fukushima
> >> Sent: May 13, 2008 8:22 AM
> >> Subject: RE: [mapguide-internals] MGOS 2.0.1 status
> >> Hi Mike,
> >> If you prepare the 1.0.6 release that sounds good.
> >> Chris is currently at Where 2.0, but perhaps we can get him to
> integrate the changes when he has some time. Chris?
> >> Tom
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike
> Adair
> >> Sent: Tuesday, May 13, 2008 9:12 AM
> >> Tom,
> >> I've already fixed the errors that were reported from the 1.0.5 release
> >> - assuming that the problem with the incorrect coordinates in Firefox
> >> was just having the warning popup (http://trac.osgeo.org/fusion/ticket/2).
> >> I've been testing with some of the MapGuide templates with no problems,
> >> but extra testing by others is always welcome. The change to the
> >> templates to remove the fusionError alerts would have to happen in MGOS
> >> or wherever those live however.
> >> I could prepare a Fusion 1.0.6 release with what is there now fairly
> >> quickly if desired. I could also assist with resolving problems getting
> >> it integrated with MGOS if needed.
> >> Mike
> >> Tom Fukushima wrote:
> >>> Mike,
> >>> Before I consider that, what's the time frame for all these fixes,
> > and will they be tested (for at least basic functionality) on the MGOS
> > stream before we get them?
> >>> Tom
> > Adair
> >>> Sent: Tuesday, May 13, 2008 8:39 AM
> >>> Speaking for myself, I would feel a lot more comfortable if MGOS2.0.1
> >>> shipped with the current 1.0 branch, or preferably if I made a a new
> >>> 1.0.6 release of Fusion.
> >>> Also, I'm not sure what end users prefer, but in the MapGuide templates,
> >>> the fusionError method should remove the alert() call. This would mean
> >>> that it would fail silently rather than showing the popup.
> >>> Zac: how is it broken? I'm testing tiled and untiled maps in IE and
> >>> Firefox and haven't encountered any errors yet, but I'm also not testing
> >>> any redlining functions.
> >>> Mike
> >>> Zac Spitzer wrote:
> >>>> the error about units in fixed in SVN, it is important to remember
> >>>> that that error relates to getting the tiled maps under fusion to
> >>>> render with correct co-ordinates. IE now works correctly, Firefox is
> >>>> broken.
> >>>> Anyone doing any digitizing, redlining etc with tiled fusion maps with
> >>>> 2.0.1 will be getting corrupt data
> >>>> z
> >>>> On Tue, May 13, 2008 at 12:27 PM, Zac Spitzer
> >>>>> Is 2.0.1 expected to resolve the server stability issues with Mapguide?
> >>>>> On Tue, May 13, 2008 at 8:47 AM, Jason Birch
> > <Jason.Birch at nanaimo.ca> wrote:
> >>>>>> Thanks for clarifying... now to find time to test :(
> >>>>>> Jason
> >>>>>> From: Tom Fukushima
> >>>>>> Oops, sorry, I was wrong in my original reply that started this thread.
> >>>>>> The version of Fusion in MGOS 2.0.1 is Fusion 1.0.4/r1331 (Chris correct
> >>>>>> me if I'm wrong again). Sorry for the confusion.
> >>>>>> _______________________________________________
> >>>>>> mapguide-internals mailing list
> >>>>>> mapguide-internals at lists.osgeo.org
> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> >>>>> Zac Spitzer -
> >>>>> http://zacster.blogspot.com (My Blog)
> >>>>> +61 405 847 168
> > Zac Spitzer -
> > +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
