[mapguide-internals] MGOS 2.0.1 status
Zac Spitzer zac.spitzer at gmail.com
Wed May 14 20:26:31 EDT 2008
I was looking for a copy of the tarball for 20x which was checked out
(not exported from subversion)
The example being each time you respin a build and drop a tar ball,
there's 100mb+ to download, whereas with subversion, it's only a few
files which can be efficiently updated via svn update.
z
On Thu, May 15, 2008 at 12:45 AM, Tom Fukushima
<tom.fukushima at autodesk.com> wrote:
> Not sure what you are asking for, but our build person is not available so unfortunately we can't make any changes.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Tuesday, May 13, 2008 11:36 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MGOS 2.0.1 status
> is it possible for the linux tarballs to include (or to provide
> another one) which is checked out and includes the subversion tags?
> On Wed, May 14, 2008 at 3:10 PM, Tom Fukushima
>> Thanks Zac,
>>  We've got the Fusion update in, so we are building with that tonight.  If all goes well, I will post that build as 2.0.1.
>>  Tom
>>  Sent: Tuesday, May 13, 2008 8:37 PM
>>  Some feedback from my cartographer,
>>  "rendering with heavy data is much better and it's its showing up
>>  exactly as i want rather than doing its own thing"
>>  z
>>  On Wed, May 14, 2008 at 12:20 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>>  > I just installed 2.0.1 on windows and then updated fusion to the
>>  > http://svn.osgeo.org/fusion/tags/fusion-1.0.6/ and it's all working
>>  > brilliantly :)
>>  > Tiled maps in fusion are reporting the correct co-ordinates in both FF2 & IE7
>>  > You will need to uninstall mapguide 2.0 first to test this build
>>  > Testing continues...
>>  > z
>>  > On Wed, May 14, 2008 at 1:49 AM, Chris Claydon
>>  > <chris.claydon at autodesk.com> wrote:
>>  >> I should be able to do it from here.
>>  >> Chris.
>>  >> From: Tom Fukushima
>>  >> Sent: May 13, 2008 8:22 AM
>>  >> Subject: RE: [mapguide-internals] MGOS 2.0.1 status
>>  >> Hi Mike,
>>  >> If you prepare the 1.0.6 release that sounds good.
>>  >> Chris is currently at Where 2.0, but perhaps we can get him to
>>  integrate the changes when he has some time. Chris?
>>  >> Tom
>>  [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Mike
>>  Adair
>>  >> Sent: Tuesday, May 13, 2008 9:12 AM
>>  >> Tom,
>>  >> I've already fixed the errors that were reported from the 1.0.5 release
>>  >> - assuming that the problem with the incorrect coordinates in Firefox
>>  >> was just having the warning popup (http://trac.osgeo.org/fusion/ticket/2).
>>  >> I've been testing with some of the MapGuide templates with no problems,
>>  >> but extra testing by others is always welcome.  The change to the
>>  >> templates to remove the fusionError alerts would have to happen in MGOS
>>  >> or wherever those live however.
>>  >> I could prepare a Fusion 1.0.6 release with what is there now fairly
>>  >> quickly if desired.  I could also assist with resolving problems getting
>>  >> it integrated with MGOS if needed.
>>  >> Mike
>>  >> Tom Fukushima wrote:
>>  >>> Mike,
>>  >>> Before I consider that, what's the time frame for all these fixes,
>>  > and will they be tested (for at least basic functionality) on the MGOS
>>  > stream before we get them?
>>  >>> Tom
>>  > Adair
>>  >>> Sent: Tuesday, May 13, 2008 8:39 AM
>>  >>> Speaking for myself, I would feel a lot more comfortable if MGOS2.0.1
>>  >>> shipped with the current 1.0 branch, or preferably if I made a a new
>>  >>> 1.0.6 release of Fusion.
>>  >>> Also, I'm not sure what end users prefer, but in the MapGuide templates,
>>  >>> the fusionError method should remove the alert() call.  This would mean
>>  >>> that it would fail silently rather than showing the popup.
>>  >>> Zac: how is it broken?  I'm testing tiled and untiled maps in IE and
>>  >>> Firefox and haven't encountered any errors yet, but I'm also not testing
>>  >>> any redlining functions.
>>  >>> Mike
>>  >>> Zac Spitzer wrote:
>>  >>>> the error about units in fixed in SVN, it is important to remember
>>  >>>> that that error relates to getting the tiled maps under fusion to
>>  >>>> render with correct co-ordinates. IE now works correctly, Firefox is
>>  >>>> broken.
>>  >>>> Anyone doing any digitizing, redlining etc with tiled fusion maps with
>>  >>>> 2.0.1 will be getting corrupt data
>>  >>>> z
>>  >>>> On Tue, May 13, 2008 at 12:27 PM, Zac Spitzer
>>  >>>>> Is 2.0.1 expected to resolve the server stability issues with Mapguide?
>>  >>>>> On Tue, May 13, 2008 at 8:47 AM, Jason Birch
>>  > <Jason.Birch at nanaimo.ca> wrote:
>>  >>>>>> Thanks for clarifying... now to find time to test :(
>>  >>>>>> Jason
>>  >>>>>> From: Tom Fukushima
>>  >>>>>> Oops, sorry, I was wrong in my original reply that started this thread.
>>  >>>>>> The version of Fusion in MGOS 2.0.1 is Fusion 1.0.4/r1331 (Chris correct
>>  >>>>>> me if I'm wrong again). Sorry for the confusion.
>>  >>>>>> _______________________________________________
>>  >>>>>> mapguide-internals mailing list
>>  >>>>>> mapguide-internals at lists.osgeo.org
>>  >>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>  >>>>> Zac Spitzer -
>>  >>>>> http://zacster.blogspot.com (My Blog)
>>  >>>>> +61 405 847 168
>>  > Zac Spitzer -
>>  > +61 405 847 168
>>  Zac Spitzer -
>>  +61 405 847 168
> Zac Spitzer -
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals mailing list
