[mapguide-internals] Motion: release MGOS 2.0.1
Rock Beans
rockbeans at gmail.com
Fri May 16 13:32:46 EDT 2008
I agree, get all the fixes in the releases if your going to spend your
valuable time doing sub-release installers.
On a side note: How does the SVN revision collolate to the actual installer
version? For example, the latest MapGuide installer for Windows on the
download server is MgServerSetup-2.0.1.2716.exe but the SVN revision is
3000+. How do you connect the two so you know what has been changed? I
assumed the 2716 was the SVN revision. If this is true where do we get the
latest MapGuide releases then?
The Rock
On Fri, May 16, 2008 at 12:17 PM, Jason Birch <Jason.Birch at nanaimo.ca>
wrote:
> In the future, I think that we should be using the latest point-release
> of FDO for new releases. This one looks like it made it out with 3.3.0
> instead of 3.3.1. It looks like 3.3.1 only fixed four issues though
> (and only the ODBC and ArcSDE ones are important for most users).
> Jason
> -----Original Message-----
> From: Tom Fukushima
> Subject: [mapguide-internals] Motion: release MGOS 2.0.1
> I motion that we release the posted MGOS 2.0.1.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
