[mapguide-internals] MapGuide Open Source
2.1-whereisthecontinuous integration system ????
Jason Birch
Jason.Birch at nanaimo.ca
Mon Nov 17 16:55:35 EST 2008
WiX supports custom actions (c++, C# and VB.Net apparently), so if we
have to do it that way that would be great.
It also has a bunch of plugins that bundle things that are common custom
actions, including one for setting IIS properties, and you can "harvest"
an existing website to import the required XML for this. If we can use
this "internal" support rather than a custom action we have to maintain,
I think I'd prefer that. It keeps more of the setup declarative. Where
I think we might have to get into custom actions is when/if we move to
allowing the user to choose which website(s?) to install the mapguide
virtual directories to, which app pool to use, etc...
Along these lines, how does Server currently get registered? Is it a
post-install step that calls mgserver with the install parameter, or an
sc command, or something else? I think that WiX has code for
registering services via the Windows APIs as well.
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Monday, November 17, 2008 13:45
To: MapGuide Internals Mail List
Cc: Davor Klemen
Subject: RE: [mapguide-internals] MapGuide Open Source
Hi Jason,
Jason wrote:
> IIS installation is likely going to be a bit of a challenge. WiX
> includes an extension for IIS, but it's not all that well documented.
I believe we have a "custom action" to do this in the current installer.
If WiX can run "custom actions", perhaps as a separate executable, we
can get the source code for this and use it. Can you check to see what
WiX supports here?
Thanks
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
