[mapguide-internals] MapGuide Open Source 2.1-whereisthecontinuous integration system ????
Tom Fukushima tom.fukushima at autodesk.com
Mon Nov 17 17:27:01 EST 2008
Hi Jason,
Jason wrote...
> Along these lines, how does Server currently get registered?  Is it a
> post-install step that calls mgserver with the install parameter, or an
> sc command, or something else?  I think that WiX has code for
> registering services via the Windows APIs as well.
We believe that it is a call to "mgserver.exe install" at the end.  We're only 98.5% sure though, and Tim who could give us an answer in one second, is on vacation until January.
That said, I think that we should use the same approach as it keeps the server's "service install" and the installer's "service install" from getting out of sync.
Tom
More information about the mapguide-internals mailing list
