[mapguide-internals] RE: CSMap in OEM.sln
Jason Birch
Jason.Birch at nanaimo.ca
Mon Nov 17 18:55:50 EST 2008
Oh, thanks Brent, Jack.
That seems to have got me past that error and everything compiles fine
and installs to Server/bin/release (after I copy FDO into Release for
the xcopy process).
Now when I try to start mgserver, I'm getting:
<2008-11-17T15:38:10> 2968
Error: The coordinate system initialization failed.
StackTrace:
- MgServer.open() line 849 file
d:\osgeo\mapguide\server\src\core\Server.cpp The coordinate system
I'm guessing that either:
- some required files aren't being copied to the server/bin/release
folder in the Server's post-build OR
- I'm missing an environmental variable or something else required for
CSMap
Any ideas?
Thanks,
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jack
Lee
Sent: Monday, November 17, 2008 15:17
To: MapGuide Internals Mail List
Subject: [mapguide-internals] RE: CSMap in OEM.sln
Hi Jason,
Brent Robinson has problems sending the email. Below is his responds:
Sent: Monday, November 17, 2008 6:09 PM
To: 'mapguide-internals at lists.osgeo.org'
Subject: FW: CSMap in OEM.sln
Hi Jason,
The error in G026 will be fixed in G027.
For G026, it can be worked around by getting
providers/SHP/inc/IExtendedSelect.h and copying it to your G026 inc/SHP
directory.
Brent.
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Monday, November 17, 2008 5:49 PM
Subject: [mapguide-internals] CSMap in OEM.sln
I was trying to build from trunk, and found that I had to compile CSMap
individually. Should this be added to the OEM sln? Should I enter a
ticket?
Also, I'm getting an odd error when trying to build trunk against FDO
G026:
1>.\GwsPreparedFeatureQuery.cpp(229) :
error C2660: 'FdoIBaseSelect::SetOrderingOption' : function does not
take 2 arguments
Has anyone else seen this? It's quite possible that my environment is
messed up with too many FDOs.
Jason
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
