[mapguide-internals] RE: CSMap in OEM.sln
Hugues Wisniewski hugues.wisniewski at autodesk.com
Mon Nov 17 19:13:27 EST 2008
Hi Jason,
The location of the coordinate system dictionaries is given by the system variable MENTOR_DICTIONARY_PATH
So, if this value is not defined or points to another location that the one required, that might be the cause of the error.
Or the dictionaries are simply not built
Is it a Windows build? Linux?
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, November 17, 2008 3:56 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RE: CSMap in OEM.sln
Oh, thanks Brent, Jack.
That seems to have got me past that error and everything compiles fine
and installs to Server/bin/release (after I copy FDO into Release for
the xcopy process).
Now when I try to start mgserver, I'm getting:
<2008-11-17T15:38:10>   2968
 Error: The coordinate system initialization failed.
 StackTrace:
  - MgServer.open() line 849 file
d:\osgeo\mapguide\server\src\core\Server.cpp    The coordinate system
I'm guessing that either:
 - some required files aren't being copied to the server/bin/release
folder in the Server's post-build OR
 - I'm missing an environmental variable or something else required for
CSMap
Any ideas?
Thanks,
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jack
Lee
Sent: Monday, November 17, 2008 15:17
Subject: [mapguide-internals] RE: CSMap in OEM.sln
Hi Jason,
Brent Robinson has problems sending the email. Below is his responds:
Sent: Monday, November 17, 2008 6:09 PM
To: 'mapguide-internals at lists.osgeo.org'
Subject: FW: CSMap in OEM.sln
Hi Jason,
The error in G026 will be fixed in G027.
For G026, it can be worked around by getting
providers/SHP/inc/IExtendedSelect.h and copying it to your G026 inc/SHP
directory.
Brent.
Birch
Sent: Monday, November 17, 2008 5:49 PM
Subject: [mapguide-internals] CSMap in OEM.sln
I was trying to build from trunk, and found that I had to compile CSMap
individually.  Should this be added to the OEM sln?  Should I enter a
ticket?
Also, I'm getting an odd error when trying to build trunk against FDO
G026:
1>.\GwsPreparedFeatureQuery.cpp(229) :
  error C2660: 'FdoIBaseSelect::SetOrderingOption' : function does not
take 2 arguments
Has anyone else seen this?  It's quite possible that my environment is
messed up with too many FDOs.
Jason
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
