[mapguide-internals] Help needed with Ubuntu build error with DWF
Zac Spitzer
zac.spitzer at gmail.com
Thu Nov 20 19:51:21 EST 2008
I am trying to build mapguide from trunk on ubuntu 8.10 at the moment
following http://wiki.osgeo.org/wiki/Building_MapGuide_on_Ubuntu_8.04
Linux zserver 2.6.27-7-generic #1 SMP Tue Nov 4 19:33:20 UTC 2008 i686 GNU/Linux
http://trac.osgeo.org/mapguide/ticket/719
/home/zac/mapguide-trunk/Oem/ACE/ACE_wrappers
/home/zac/mapguide-trunk/Oem /home/zac/mapguide-trunk
ace: Build Successful ..........................
dwfcore: Initialization...........................
/home/zac/mapguide-trunk/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./ltmain.sh'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in Makefile.am.
configure.in:11: required file `./config.guess' not found
configure.in:11: required file `./config.sub' not found
autoreconf: automake failed with exit status: 1
dwfcore: Configure/Build ...........................
/home/zac/mapguide-trunk/Oem/DWFTK7.1/develop/global/src/dwfcore
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++-4.1 accepts -g... yes
checking for style of include used by make... GNU
checking dependency style of g++-4.1... gcc3
configure: error: cannot run /bin/sh ./config.sub
make: *** No targets specified and no makefile found. Stop.
DWFCORE 1.0: Error build failed (0).................
any ideas?
z
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
More information about the mapguide-internals
