[mapguide-internals] Help needed with Ubuntu build error with DWF
Helio Chissini de Castro
helio at kde.org
Fri Nov 21 04:12:28 EST 2008
On Quinta 20 Novembro 2008, Zac Spitzer wrote:
> I am trying to build mapguide from trunk on ubuntu 8.10 at the moment
> following http://wiki.osgeo.org/wiki/Building_MapGuide_on_Ubuntu_8.04
> Linux zserver 2.6.27-7-generic #1 SMP Tue Nov 4 19:33:20 UTC 2008 i686
> GNU/Linux
> http://trac.osgeo.org/mapguide/ticket/719
> /home/zac/mapguide-trunk/Oem/ACE/ACE_wrappers
> /home/zac/mapguide-trunk/Oem /home/zac/mapguide-trunk
> ace: Build Successful ..........................
> dwfcore: Initialization...........................
> /home/zac/mapguide-trunk/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore
> libtoolize: putting auxiliary files in `.'.
> libtoolize: copying file `./ltmain.sh'
> libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
> libtoolize: rerunning libtoolize, to keep the correct libtool macros
> in-tree. libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in
> Makefile.am. configure.in:11: required file `./config.guess' not found
> configure.in:11: required file `./config.sub' not found
> autoreconf: automake failed with exit status: 1
> any ideas?
automake is not so common to fail, so must be something that the log is not
telling you, or your auto*tools + libtools is borked.
[]'s
KDE Developer
Brasil/South America Primary Contact
More information about the mapguide-internals
