[mapguide-internals] Help needed with Ubuntu build error with DWF
Zac Spitzer
zac.spitzer at gmail.com
Fri Nov 21 04:18:00 EST 2008
before that ACE compiles ok and i did the whole linuxapt stuff without problem
any quick way to test the bork factor?
z
On Fri, Nov 21, 2008 at 8:12 PM, Helio Chissini de Castro <helio at kde.org> wrote:
> On Quinta 20 Novembro 2008, Zac Spitzer wrote:
>> I am trying to build mapguide from trunk on ubuntu 8.10 at the moment
>> following http://wiki.osgeo.org/wiki/Building_MapGuide_on_Ubuntu_8.04
>> Linux zserver 2.6.27-7-generic #1 SMP Tue Nov 4 19:33:20 UTC 2008 i686
>> GNU/Linux
>> http://trac.osgeo.org/mapguide/ticket/719
>> /home/zac/mapguide-trunk/Oem/ACE/ACE_wrappers
>> /home/zac/mapguide-trunk/Oem /home/zac/mapguide-trunk
>> ace: Build Successful ..........................
>> dwfcore: Initialization...........................
>> /home/zac/mapguide-trunk/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore
>> libtoolize: putting auxiliary files in `.'.
>> libtoolize: copying file `./ltmain.sh'
>> libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.in and
>> libtoolize: rerunning libtoolize, to keep the correct libtool macros
>> in-tree. libtoolize: Consider adding `-I m4' to ACLOCAL_AMFLAGS in
>> Makefile.am. configure.in:11: required file `./config.guess' not found
>> configure.in:11: required file `./config.sub' not found
>> autoreconf: automake failed with exit status: 1
>> any ideas?
> automake is not so common to fail, so must be something that the log is not
> telling you, or your auto*tools + libtools is borked.
> []'s
> KDE Developer
> Brasil/South America Primary Contact
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
More information about the mapguide-internals
