[mapguide-internals] mapguide in a load balanced environmnet
Zac Spitzer
zac.spitzer at gmail.com
Tue Nov 25 15:18:52 EST 2008
at the moment the easiest thing to do is to map the packages directory
for each server
to a common (shared) folder for all server and like you suggested
restoring the packages
via mapadmin on the slave servers
On Wed, Nov 26, 2008 at 2:52 AM, Riccardo Pucci
<riccardo.pucci at gruppoesc.it> wrote:
> Hi all,
> I have some question (maybe stupid) about mapguide in a load balanced
> environment. I still had not time to set up en environment to test load
> balancing capabilities, but there is something I don't understand about
> repository management: in a load balanced environment there are two (or
> more) installation of server component in different machine, what about the
> repository "library://"? It can be shared from the two server or there
> should be two different repository with the same content? In the case of
> distinct repository, what happen for example while authoring with studio? or
> restoring packages with mapadmin web application?
> thanks
> Riccardo Pucci
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
