[mapguide-internals] mapguide in a load balanced environmnet
Jason Birch Jason.Birch at nanaimo.ca
Tue Nov 25 15:47:29 EST 2008
Hi Riccardo,
No stupid questions :)
In addition to Zak's suggestion, you may want to consider using
unmanaged resources.  This allows your packages to remain small (faster
import/export) and the data files can be replicated differentially using
something like robocopy/rsync.  Make sure that only one of your MapGuide
servers (possibly a behind-dmz master server) has authoring capabilities
turned on in the web config.
This doesn't help if you are going to be allowing your users to update
data in the Library though.  Something that might be useful in the
future is the ability to configure MapGuide to talk to a BDB replication
manager rather than a locally installed database:
http://www.oracle.com/technology/documentation/berkeley-db/db/ref/rep/in
tro.html
BTW, this kind of question should be directed to the mapguide-users
mailing list, not internals.
Thanks,
Jason
-----Original Message-----
Sent: Tuesday, November 25, 2008 07:52
Subject: [mapguide-internals] mapguide in a load balanced environmnet
[snip]
In a load balanced environment there are two (or
more) installation of server component in different machine, what about
the repository "library://"? It can be shared from the two server or
there should be two different repository with the same content? In the
case of distinct repository, what happen for example while authoring
with studio? or restoring packages with mapadmin web application?
More information about the mapguide-internals mailing list
