[mapguide-internals] RE: GDAL Stability (Was: Project Sponsorship)
Tom Fukushima tom.fukushima at autodesk.com
Tue Nov 25 16:07:04 EST 2008
We didn't do any testing with MrSID and ECW.
We don't plan on doing MrSID and ECW, because if there are problems we don't have any control of those libraries so we would have to add workarounds in the GDAL provider code; and that is more work than we can take on.  Threading problems are one of the worst time sinks.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, November 25, 2008 1:55 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] GDAL Stability (Was: Project Sponsorship)
Hi Tom,
Did you do any testing against MrSID or ECW libraries, and if so, care
to share the results?
I know there's not much you can do about this on the MapGuide level, and
I know that Frank has indicated some pain about the wavelet drivers
before.  Bit painful for those of use that don't have enough storage on
our MapGuide servers though :)
Jason
Subject: RE: [mapguide-internals] RE: Project Sponsorship
[snip]
BTW, we spent a lot of time looking into the GDAL provider problem
recently and did not find any stability problems with GeoTIFF. We were
going to update the ticket with the information, but it looks like that
hasn't been done yet. There is a memory leak and that will cause a crash
after a while, but we don't see any threading problems.  So with MGOS
2.0.2 and GeoTIFF (use GDAL to create these) things are stable.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
