[mapguide-internals] MapGuide RFC 57 - Refining the linux
buildprocess and generating install packages
Zac Spitzer
zac.spitzer at gmail.com
Wed Nov 26 01:34:25 EST 2008
I was purely summarising what Helio has posted here on the list :)
Jason, your comments about the berkley replication stuff was quite
interesting, but was
that in fact what the old site server / support server stuff was based on?
GEOS doesn't have a binary windows distribution does it?
z
On Wed, Nov 26, 2008 at 5:06 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Thanks for putting that together Zac.
> I'm not sure which OEM components have been modified specifically for MapGuide. I'm pretty sure that AGG has been, and we have to make sure that we only bundle the older 2.4 version with any releases that we do to avoid contaminating our code with GPL. Are there any other OEM components that have modifications that haven't been contributed/adopted upstream? I see that at least GEOS and GD (libpng) have had some code modifications made to support 64 bit compilation.
> Tom, I'd agree that the Windows build process is easy, but maybe too easy :) I'd love to try swapping out some of the OEM components in the Windows build/packages for 2.1, especially Apache, PHP, and GEOS. Unfortunately, I think that this may be a bit optimistic given that some packages (such as ACE) haven't been updated in over four years, and I don't have the developer chops to fix anything I run into.
> Jason
> ________________________________
> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Zac Spitzer
> Sent: Tue 2008-11-25 6:50 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] MapGuide RFC 57 - Refining the linux buildprocess and generating install packages
> Following up on the various discussions about the linux build process
> I have created a draft RFC
> for refining the linux build process and generating install packages.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc57
> z
> Zac Spitzer -
> http://zacster.blogspot.com <http://zacster.blogspot.com/>
> +61 405 847 168
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
