[mapguide-internals] MapGuide RFC 57 - Refining the
linuxbuildprocess and generating install packages
Jason Birch
Jason.Birch at nanaimo.ca
Wed Nov 26 02:53:16 EST 2008
It's encouraging to me to hear that Tom is enthusiastic about this; I took the general silence around Linux builds to be a sign of disapproval. Have to learn to stop looking over my shoulder.
I believe that the site server/support server used MapGuide's internal TCP/IP to communicate between the various services. BDB replication would allow you to run a repository "farm", with a single master and multiple slaves. Writes all go to one repository, and reads get balanced to the slaves. Apparently it allows the client software to elect a new master from the slaves if the primary is down too. This would nicely get around the current problems with load balancing and sessions / server affinity. I didn't get a chance to look at it in depth, but it seemed to be a good fit.
As far as I know GEOS doesn't have a windows binary, but it should be relatively straightforward to build it. I'm only a couple hours away from Paul's doorstep if I can't get it to compile :)
Jason
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MapGuide RFC 57 - Refining the linuxbuildprocess and generating install packages
I was purely summarising what Helio has posted here on the list :)
Jason, your comments about the berkley replication stuff was quite
interesting, but was
that in fact what the old site server / support server stuff was based on?
GEOS doesn't have a binary windows distribution does it?
More information about the mapguide-internals
