[mapguide-internals] Problem with "Installing Sample Data and
Sample Applications"
Tom Fukushima
tom.fukushima at autodesk.com
Tue Sep 2 20:40:10 EDT 2008
Not sure what those errors are, but it looks like a server error to me...check the output window in your Visual Studio output window and the server error log (it will be in the logs subdirectory of the server executable). There might be some information in there that is useful.
When you are running the server from VS ensure that you have put "test" as a command line argument for the executable.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of sergi nistal
Sent: Saturday, August 30, 2008 12:46 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Problem with "Installing Sample Data and Sample Applications"
I´m installing a debug version of Mapguide 2.0.1 with FDO 3.3.1 on Windows Vista from source code.
I´m 'Installing Sample Data and Sample Applications' (document with the same name) and when I make image 1 the result is image 2 (paragraph 'Instructions for Loading the Sample Data on the Server'), the result of http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php is image 3 and the result of http://localhost/mapguide/phpviewersample/ajaxviewersample.php is image 4 (paragraph 'Setting up Sample Applications (PHP) with Apache'), Is everythong ok? Should not bring up a map instead of the whole orange background? Should interrogations appear beside the section of the layers (Islands, Hydrography, ...)? and finally the result of http://localhost/mapguide/webstudio/index.html is image 5,
Should not appear libraries Sheboygan in section 'Site Explorer'?
If you need other data, please contact me. Thank you very much.
_________________________________________________________________
¡Lo mejor de MSN y Windows Live en tu móvil! Hotmail, Messenger, Spaces... Pruébalo ya y disfruta de todas sus ventajas donde quieras
http://serviciosmoviles.es.msn.com/
More information about the mapguide-internals
