[mapguide-internals] Sheboygan package
sergi nistal
serginistal at hotmail.com
Thu Sep 4 14:35:58 EDT 2008
Hi Tom,
I am trying to make a "final thesis" based on MapGuide application. The
project is to determine what kind of tool (see the posibilities of the tool, found defects, update documentation, ...) and try to extend it with some new feature. The
installers I have worked well, but now I'm trying from source.
Best regards.
> From: tom.fukushima at autodesk.com
> To: mapguide-internals at lists.osgeo.org
> Date: Thu, 4 Sep 2008 11:20:42 -0700
> Subject: RE: [mapguide-internals] Sheboygan package
> Hi Sergi,
> Can you tell us what you are trying to do? Are you fixing a defect, adding a new feature, updating our documentation, or something else? If some of the developers here see that you will be contributing back to the project, they may be more motivated to help you out---a session on IRC can be quite a bit more productive than email.
> Have you been able to get the released version of MGOS to work via the installers that we provide? The Apache install of the web tier will work on Vista without problems.
> Cheers
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of sergi nistal
> Sent: Wednesday, September 03, 2008 12:07 PM
> To: MapGuide Internals Mail List
> Hi,
> I´m installing a debug version of Mapguide 2.0.1 with FDO 3.3.1 on Windows Vista from source code.
> I´m 'Installing Sample Data and Sample Applications' (document with the same name) and when I make image 1
> the result is image 2 (paragraph 'Instructions for Loading the Sample Data on the Server'), the result of
> http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php is image 3 and the result of
> http://localhost/mapguide/phpviewersample/ajaxviewersample.php is image 4 (paragraph 'Setting up Sample
> Applications (PHP) with Apache'), Is everythong ok? Should not bring up a map instead of the whole
> orange background? Should interrogations appear beside the section of the layers
> (Islands, Hydrography, ...)? and finally the result of http://localhost/mapguide/webstudio/index.html is
> image 5, Should not appear libraries Sheboygan in section 'Site Explorer'?
> If you need other data, please contact me. Thank you very much.
> > Date: Tue, 2 Sep 2008 21:51:01 +0200
> > From: ks at geograf.dk
> > Subject: Re: [mapguide-internals] Sheboygan package
> > What is the problem with the Sheboygan package?
> > Regards, Kenneth Skovhede, GEOGRAF A/S
> > sergi nistal skrev:
> > > Hi,
> > > Is there any package of example apart Sheboygan.mgp to prove mapguide? The package Sheboygan don´t work for me.
> > > Thanks
> > > _________________________________________________________________
> > > Llega la nueva temporada. Consulta las nuevas tendencias en MSN Estilo
> > > http://estilo.es.msn.com/moda/_______________________________________________
> > > mapguide-internals mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
¡Entra en el Club oficial de Messenger y te enterarás de todas las novedades!
http://www.vivelive.com/ilovemessenger
More information about the mapguide-internals
