[mapguide-internals] Sheboygan package
sergi nistal serginistal at hotmail.com
Wed Sep 3 14:07:14 EDT 2008
I´m installing a debug version of Mapguide 2.0.1 with FDO 3.3.1 on Windows Vista from source code.
I´m 'Installing Sample Data and Sample Applications' (document with the same name) and when I make image 1
the result is image 2 (paragraph 'Instructions for Loading the Sample Data on the Server'), the result of
http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php is image 3 and the result of
http://localhost/mapguide/phpviewersample/ajaxviewersample.php is image 4 (paragraph 'Setting up Sample
Applications (PHP) with Apache'), Is everythong ok? Should not bring up a map instead of the whole
orange background? Should interrogations appear beside the section of the layers
(Islands, Hydrography, ...)? and finally the result of http://localhost/mapguide/webstudio/index.html is
image 5, Should not appear libraries Sheboygan in section 'Site Explorer'?
If you need other data, please contact me. Thank you very much.
> Date: Tue, 2 Sep 2008 21:51:01 +0200
> From: ks at geograf.dk
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Sheboygan package
> What is the problem with the Sheboygan package?
> Regards, Kenneth Skovhede, GEOGRAF A/S
> sergi nistal skrev:
> > Hi,
> > Is there any package of example apart Sheboygan.mgp to prove mapguide? The package Sheboygan don´t work for me.
> > Thanks
> > _________________________________________________________________
> > Llega la nueva temporada. Consulta las nuevas tendencias en MSN Estilo
> > http://estilo.es.msn.com/moda/_______________________________________________
> > mapguide-internals mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
