[mapguide-internals] Sheboygan package
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Sep 4 03:20:31 EDT 2008
It appears that you images got lost in the mail.
The usual errors are:
1. Downloading the sample data with IE, renames the files to .zip,
making them unavalible in MapGuide
2. Viewing a map with FireFox3 only displays the background.
If there is no "Samples/Sheyboygan" folder after the package restore,
the problem is with the package restore.
If you can view the demo solution, but with no actual map, you have
restored the package,
but at most likely using Firefox3 to view it, but have not  patched the
server.
Regards, Kenneth Skovhede, GEOGRAF A/S
sergi nistal skrev:
> Hi,
> I´m installing a debug version of Mapguide 2.0.1 with FDO 3.3.1 on Windows Vista from source code.
> I´m 'Installing Sample Data and Sample Applications' (document with the same name) and when I make image 1
> the result is image 2 (paragraph 'Instructions for Loading the Sample Data on the Server'), the result of
> http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php is image 3 and the result of
> http://localhost/mapguide/phpviewersample/ajaxviewersample.php is image 4 (paragraph 'Setting up Sample
> Applications (PHP) with Apache'), Is everythong ok? Should not bring up a map instead of the whole
> orange background? Should interrogations appear beside the section of the layers
> (Islands, Hydrography, ...)? and finally the result of http://localhost/mapguide/webstudio/index.html is
> image 5, Should not appear libraries Sheboygan in section 'Site Explorer'?
> If you need other data, please contact me. Thank you very much.
>> Date: Tue, 2 Sep 2008 21:51:01 +0200
>> From: ks at geograf.dk
>> To: mapguide-internals at lists.osgeo.org
>> Subject: Re: [mapguide-internals] Sheboygan package
>> What is the problem with the Sheboygan package?
>> sergi nistal skrev:
>>> Hi,
>>> Is there any package of example apart Sheboygan.mgp to prove mapguide? The package Sheboygan don´t work for me.
>>> Thanks
>>> _________________________________________________________________
>>> Llega la nueva temporada. Consulta las nuevas tendencias en MSN Estilo
>>> http://estilo.es.msn.com/moda/_______________________________________________
>>> mapguide-internals mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
