FW: [mapguide-internals] Sheboygan package
sergi nistal serginistal at hotmail.com
Wed Sep 17 14:02:08 EDT 2008
I had installed php 5.2.5, but just in case, I have updated to 5.2.6, but it happens the same, how could you tell me which files are involved in these services?.
PD-I have apache2.2.8 and mysql5.0.51a
From: serginistal at hotmail.comTo: javier.mrtn at hotmail.com; serginistal at hotmail.comSubject: FW: [mapguide-internals] Sheboygan packageDate: Tue, 16 Sep 2008 18:33:19 +0200
From: serginistal at hotmail.comTo: serginistal at hotmail.comSubject: FW: [mapguide-internals] Sheboygan packageDate: Mon, 15 Sep 2008 12:32:10 +0200
Hi, firts I´m sorry for so many mails. The problem was that I used FireFox3.Now I have other problems (see images.rar):1- The result of the image 'mapagent1.jpg' is 'mapagent2.jpg', it´s ok (argument out of range)?2- Warning in 'find address' (image with the same name). It works but it returns this warning:Warning:Call-timepass-by-reference has been deprecated; If you would like topass it byreference, modify the declaration of xml_set_object(). Ifyou would liketo enable call-time pass-by-reference, you cansetallow_call_time_pass_reference to true in your INI fileinC:\MAPGUIDE2\mapguide-2.0.1\Web\src\phpviewersample\findaddress\kd_xmlrpc.phponline 83 (and other lines)3- Problem in 'query features'. Image 'query features1.jpg'. In the box 'Layer' only appears '>', in the box 'Property' appears nothing, ...4- The same problem that 3 in 'theme player'.5- To use 'plot as DWF' I need Autodesk DWF Viewer, don´t?Thanks.
¡Sé solidario, haz clic! Por cada búsqueda que hagas desde Windows Live Search, estarás ayudando a los que más lo necesitan. Messenger TV
¡Trónchate de risa con los mejores capítulos de South Park en MSN Vídeo!
_________________________________________________________________
¿Sigue el calor? Consulta MSN El tiempo
http://eltiempo.es.msn.com/
Name: find address.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080917/ceabb78e/findaddress-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080917/ceabb78e/mapagent1-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080917/ceabb78e/mapagent2-0001.jpg
Name: query features1.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20080917/ceabb78e/queryfeatures1-0001.jpg
More information about the mapguide-internals mailing list
