[mapguide-internals] Sheboygan package
Jason Birch Jason.Birch at nanaimo.ca
Wed Sep 17 14:31:08 EDT 2008
For the find_address error, it seems that demo is using a deprecated feature of PHP.  To work around this (until PHP6, where the option is removed) you need to adjust your php.ini file as follows:
allow_call_time_pass_reference=on
For the mapagent problem, could you click on the pane that is displaying the error, then right-click and go to properties.  Copy/paste the entire URL from this dialogue (might take a bit of work if it's multi-line) and let us know what it says?
Not sure on queryfeatures...
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of sergi nistal
Sent: Wednesday, September 17, 2008 11:02
To: MapGuide Internals Mail List
Subject: FW: [mapguide-internals] Sheboygan package
I had installed php 5.2.5, but just in case, I have updated to 5.2.6, but it happens the same, how could you tell me which files are involved in these services?.
PD-I have apache2.2.8 and mysql5.0.51a
From: serginistal at hotmail.comTo: javier.mrtn at hotmail.com; serginistal at hotmail.comSubject: FW: [mapguide-internals] Sheboygan packageDate: Tue, 16 Sep 2008 18:33:19 +0200
From: serginistal at hotmail.comTo: serginistal at hotmail.comSubject: FW: [mapguide-internals] Sheboygan packageDate: Mon, 15 Sep 2008 12:32:10 +0200
Hi, firts I´m sorry for so many mails. The problem was that I used FireFox3.Now I have other problems (see images.rar):1- The result of the image 'mapagent1.jpg' is 'mapagent2.jpg', it´s ok (argument out of range)?2- Warning in 'find address' (image with the same name). It works but it returns this warning:Warning:Call-timepass-by-reference has been deprecated; If you would like topass it byreference, modify the declaration of xml_set_object(). Ifyou would liketo enable call-time pass-by-reference, you cansetallow_call_time_pass_reference to true in your INI fileinC:\MAPGUIDE2\mapguide-2.0.1\Web\src\phpviewersample\findaddress\kd_xmlrpc.phponline 83 (and other lines)3- Problem in 'query features'. Image 'query features1.jpg'. In the box 'Layer' only appears '>', in the box 'Property' appears nothing, ...4- The same problem that 3 in 'theme player'.5- To use 'plot as DWF' I need Autodesk DWF Viewer, don´t?Thanks.
¡Sé solidario, haz clic! Por cada búsqueda que hagas desde Windows Live Search, estarás ayudando a los que más lo necesitan. Messenger TV
¡Trónchate de risa con los mejores capítulos de South Park en MSN Vídeo!
_________________________________________________________________
¿Sigue el calor? Consulta MSN El tiempo
http://eltiempo.es.msn.com/
More information about the mapguide-internals mailing list
