[mapguide-internals] RFC55 Addendum - New datum transformation
technique in CsMap will need to be exposed in the API
Hugues Wisniewski
hugues.wisniewski at autodesk.com
Thu Sep 25 20:20:04 EDT 2008
Hi all,
I just added the following section to the RFC55: http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
Addendum - New datum transformation technique in CsMap will need to be exposed in the API ¶
There is a new ticket logged against Cs-Map that fixes the 3Parameter conversion technique by introducing a new technique named "Geocentric"
http://trac.osgeo.org/csmap/ticket/4
When this defect is fixed, the switch to the Cs-Map implementation will need to have the MgCoordinateSystem API expose it via a new entry inside the MgCoordinateSystemGeodeticTransformationMethod enum
That is the only change in the API that is expected from the move to CsMap
Thanks
Hugues
More information about the mapguide-internals
