[mapguide-internals] Is 2.1 going to support 64-bit
Zac Spitzer
zac.spitzer at gmail.com
Wed Apr 1 03:08:41 EDT 2009
and whats the recommended distro for the least pain, ie what are the
Autodesk's team using?
z
On Wed, Apr 1, 2009 at 2:39 AM, Bruce Dechant
<bruce.dechant at autodesk.com> wrote:
> Helio,
> Did you get it working on Windows with 5.4? Reason I ask is that when I built with ACE 5.4 for Windows the IP address was switched, ie: 144.111.1.2 would end up being transposed into 2.1.111.144. If I entered the IP address backwards in the webconfig.ini it worked. When I upgraded to ACE 5.6 this bug went away on Windows.
> What issues are you seeing with dbxml? I have been using 64bit server on Windows for several days now without issue.
> Thanks,
> Bruce
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
> Sent: Monday, March 30, 2009 5:43 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Is 2.1 going to support 64-bit
> On Segunda-feira 30 Março 2009, Bruce Dechant wrote:
>> Zac,
>> 2.1 won't support 64bit as it requires a switch to ACE5.6. We are currently
>> on ACE5.4. The plan is to update to ACE5.6 after 2.1 is released as we
>> don't want to destabilize 2.1 by switching ACE versions this close to
>> release.
>> Thanks,
>> Bruce
> ACE indeed is not an issue, since i already did a 64 bit compilation, working.
> The real issue is dbxml, which can't be upgraded from the internal one and any
> small minor version change on the base db cause the most unusual crashes.
> 64 bits in linux is doable, but requires a little effort and i don't think
> would be possible for a mapguide release
> KDE Developer
> Brasil/South America Primary Contact
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
