[mapguide-internals] Exception Handling for Memory limitations
+ Patch for #480 & #520
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri Apr 3 03:09:03 EDT 2009
Note that ByteSink::ToFile is a general purpose method, and so we can't code tile-cache specific behavior in there. Any tile-specific behavior needs to go into the tile service. For example, MgServerTileService::SetTile (which writes the image stream to the tile cache) can verify the file was written, and if not do something special.
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
Sent: Friday, April 03, 2009 1:26 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Exception Handling for Memory limitations + Patch for #480 & #520
I tend to agree with jason's point... however, from a performance
perspective, it means we keep
hitting the error and throwing an exception. where as a empty file
avoid's that issue.. what to do?
writing a blank file with an additional file which can be searched
for, ie 6_6.png.error?
z
On Fri, Apr 3, 2009 at 4:16 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> This is from a non-technical perspective, but I would _much_ rather have a missing tile than a corrupt tile. IMO, if an exception is thrown and it's not possible to determine that the file was written without errors, delete it. I haven't tried this with a recent release, but I think that earlier versions were writing white tiles when exceptions were encountered. Differentiating between these failed tiles and tiles were not corrupt but had minimal information on them was difficult.
> It would be useful if the logged error included information on which file was being written as well as the reason for the exception. I've run into a few cases where bad geometry causes rendering exceptions, and tracking these down can be a royal pain.
> Jason
> From: Walt Welton-Lair [walt.welton-lair at autodesk.com]
> Sent: Thursday, April 02, 2009 8:40 PM
> Subject: RE: [mapguide-internals] Exception Handling for Memory limitations + Patch for #480 & #520
> Also, in my change I delete the file if any exception is encountered - in your case you delete it only if it's empty. Both seem like reasonable choices. When an exception occurs it's possible the file got written out completely and is valid, but it's also possible it was only partially written and therefore not valid. Any more thoughts on that?_______________________________________________
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
