[mapguide-internals] Install Structure
Jason Birch
Jason.Birch at nanaimo.ca
Sat Apr 4 03:38:50 EDT 2009
So,
It looks like the problem we were having with Fusion not recognising an alternate directory for the web extensions has gone away. I would like to propose that the installer be altered as so regardless:
c:\Program Files\OSGeo\MapGuide\Server\
c:\Program Files\OSGeo\MapGuide\Web\
c:\Program Files\OSGeo\MapGuide\CS-Map\
If I can get a consensus of 2 (are you around Jackie?) in the next little while I'll make the change tonight :) Otherwise, I'll leave as-is for now.
Jason
More information about the mapguide-internals
