[mapguide-internals] Install Structure
Jackie Ng jumpinjackie at gmail.com
Sat Apr 4 04:42:50 EDT 2009
Go for it
- Jackie
So,
It looks like the problem we were having with Fusion not recognising an alternate directory for the web extensions has gone away.  I would like to propose that the installer be altered as so regardless:
c:\Program Files\OSGeo\MapGuide\Server\
c:\Program Files\OSGeo\MapGuide\Web\
c:\Program Files\OSGeo\MapGuide\CS-Map\
If I can get a consensus of 2 (are you around Jackie?) in the next little while I'll make the change tonight :)  Otherwise, I'll leave as-is for now.
Jason
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Install-Structure-tp2584395p2584531.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
