[mapguide-internals] Patch for build.bat
Jackie Ng
jumpinjackie at gmail.com
Mon Apr 6 02:17:11 EDT 2009
I don't have access to my dev machine at the moment to take a closer look, but will this use C:\Program Files\MapGuideOpenSource2.0 as the output directory only if I supply -o=default or -o=def ?
- Jackie
I modified the build.bat a little bit to avoid doc-building and to use
existing environment variables...
-I added a additional build target allnodoc
-Also there were some quotes missing....
have a look and check it in please.
I want to use it on the build server.
UV
Index: build.bat
--- build.bat (revision 3798)
+++ build.bat (working copy)
@@ -70,6 +70,7 @@
SET MG_OUTPUT_WEB=%MG_OUTPUT%\WebServerExtensions
SET MG_BUILD_COMPONENT=
+SET MG_DEFAULT_INSTALLDIR=C:\Program Files\MapGuideOpenSource2.0
SET MG_ERROR=0
rem ==================================================
@@ -77,11 +78,11 @@
rem
rem Your paths may be different, adjust accordingly
-SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0
SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
SET GNUWIN32=C:\Program Files\GnuWin32\bin
SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
-SET ANT_HOME=%MG_DEV%\BuildTools\apache-ant-1.7.1
+IF "%ANT_HOME%" == "" SET ANT_HOME=%MG_DEV%\BuildTools\apache-ant-1.7.1
SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
@@ -105,6 +106,10 @@
SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /t:Clean %MSBUILD_VERBOSITY%
SET ANT=ant
+rem ==================================================
+rem Parameter Handling
:study_params
if (%1)==() goto pre_build_check
@@ -117,7 +122,7 @@
if "%1"=="-a" goto get_action
if "%1"=="-action" goto get_action
-if "%1"=="-w" goto get_component
+if "%1"=="-w" goto get_component
if "%1"=="-with" goto get_component
if "%1"=="-v" goto get_verbose
@@ -137,7 +142,10 @@
goto next_param
:get_output
-SET MG_OUTPUT=%2
+if "%2" == "default" SET MG_OUTPUT=%MG_DEFAULT_INSTALLDIR%
+ELSE SET MG_OUTPUT=%2
+if "%2" == "def" SET MG_OUTPUT=%MG_DEFAULT_INSTALLDIR%
SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
goto next_param
@@ -170,9 +178,14 @@
if "%2"=="web" goto next_param
if "%2"=="doc" goto next_param
if "%2"=="all" goto next_param
+if "%2"=="allnodoc" goto next_param
SET ERRORMSG=Unrecognised component: %2
goto custom_error
+rem Check Environment Vars
:pre_build_check
:check_java
if exist "%JAVA_HOME%" goto check_ant
@@ -239,15 +252,23 @@
if exist %MG_DOC_OUTPUT% rd /S /Q %MG_DOC_OUTPUT%
goto quit
+rem =======================================================
+rem Build Targets.... the all targets just carry on
:build
if "%TYPECOMPONENT%"=="oem" goto build_oem
if "%TYPECOMPONENT%"=="server" goto build_server
if "%TYPECOMPONENT%"=="web" goto build_web
if "%TYPECOMPONENT%"=="doc" goto build_doc
if "%TYPECOMPONENT%"=="all" goto build_oem
+if "%TYPECOMPONENT%"=="allnodoc" goto build_oem
SET ERRORMSG=Unrecognised component: %TYPECOMPONENT%
goto custom_error
:build_oem
echo [build]: Building Oem
%MSBUILD% %MG_OEM%\Oem.sln
@@ -256,20 +277,32 @@
echo [build]: Building Oem - CSMap
%MSBUILD% %MG_OEM%\CsMap\OpenSource.sln
if "%errorlevel%"=="1" goto error
-if not "%TYPECOMPONENT%"=="all" goto quit
+if "%TYPECOMPONENT%"=="oem" goto quit
+if "%TYPECOMPONENT%"=="server" goto quit
+if "%TYPECOMPONENT%"=="web" goto quit
+if "%TYPECOMPONENT%"=="doc" goto quit
:build_server
echo [build]: Building Server
%MSBUILD% %MG_SERVER%\Server.sln
:build_web
echo [build]: Building Web Tier
%MSBUILD% %MG_WEB_SRC%\WebTier.sln
+if "%TYPECOMPONENT%"=="allnodoc" goto quit
+rem this is left out with component allnodoc
:build_doc
echo [build]: Building Doc
pushd %MG_DOC%
@@ -277,11 +310,17 @@
popd
goto quit
+rem INSTALL Targets.... the all targets just carry on
:install
+if "%TYPECOMPONENT%"=="all" goto install_server
+if "%TYPECOMPONENT%"=="allnodoc" goto install_server
if "%TYPECOMPONENT%"=="server" goto install_server
if "%TYPECOMPONENT%"=="web" goto install_web
if "%TYPECOMPONENT%"=="doc" goto install_doc
-if "%TYPECOMPONENT%"=="all" goto install_server
goto custom_error
@@ -295,15 +334,9 @@
%XCOPY% "%MG_SERVER%\RepositoryAdmin" "%MG_OUTPUT_SERVER%\RepositoryAdmin" /EXCLUDE:svn_excludes.txt+%TYPEBUILD%_excludes.txt
echo [install]: CsMap Dictionaries
%XCOPY% "%MG_OEM%\CsMap\Dictionaries" "%MG_OUTPUT_SERVER%\CsMap\Dictionaries" /EXCLUDE:svn_excludes.txt+csmap_excludes.txt
-:install_doc
-echo [install]: Documentation
-%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\Help" /EXCLUDE:svn_excludes.txt
-echo [install]: Developer's Guide Sample Code
-%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\devguide" /EXCLUDE:svn_excludes.txt
:install_web
echo [install]: web Tier
@@ -347,8 +380,17 @@
if not exist "%MG_OUTPUT_WEB%\Apache2\modules" mkdir "%MG_OUTPUT_WEB%\Apache2\modules"
%XCOPY% /F "%MG_WEB_SRC%\mapagent\mod_mgmapagent.so" "%MG_OUTPUT_WEB%\Apache2\modules"
echo [install]: Web Tier - fusion
-%ANT% deploy -Ddeploy.home=%MG_OUTPUT_WEB%\www\fusion -f %MG_OEM%\fusion\build.xml
+%ANT% deploy -Ddeploy.home="%MG_OUTPUT_WEB%\www\fusion" -f "%MG_OEM%\fusion\build.xml"
+:install_doc
+echo [install]: Documentation
+%XCOPY% "%MG_DOC_OUTPUT%" "%MG_OUTPUT_WEB%\Help" /EXCLUDE:svn_excludes.txt
+echo [install]: Developer's Guide Sample Code
+%XCOPY% "%MG_DOC_DEVGUIDE_SAMPLES%" "%MG_OUTPUT_WEB%\www\devguide" /EXCLUDE:svn_excludes.txt
goto quit
:error
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Patch-for-build.bat-tp2591437p2591515.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
