[mapguide-internals] TCP/IP connection
Martin Morrison martin.morrison at edsi.com
Wed Apr 8 11:24:39 EDT 2009
Trevor,
If you are fiddling with TCPIP parameters and such, the default values (php.ini) for the following also need turned up.
; Resource Limits ;
max_execution_time = 60 ; Maximum execution time of each script, in seconds
max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
memory_limit = 64M ; Maximum amount of memory a script may consume
In a nutshell, if someone is on dial-up and is running a higher res monitor, it takes the script longer to download the new image than the timeout allows.  I changed the max_execution_time to 180, made a huge difference in stability.  I also set the memory_limit to 256M.
Compressing all of the possible output from the server would help also.
Martin
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Wednesday, April 08, 2009 11:14 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Version setting script - What about ANT
<deleted>
I am currently working on updates to the MapGuide TCP/IP connection infrastructure.  I suspect the PSC would be willing to wait for this update assuming it resolves some of the outstanding "lockup" issues with MapGuide.  With luck, this update may be ready sometime next week.
Thanks,
Trevor
 <deleted>
More information about the mapguide-internals mailing list
