[mapguide-internals] TCP/IP connection
Jason Birch Jason.Birch at nanaimo.ca
Wed Apr 8 11:34:48 EDT 2009
Hi Martin,
Would you mind putting this in as a ticket for the "Installer" component?  These values can be adjusted during installation.
Jason
-----Original Message-----
Sent: April-08-09 8:25 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] TCP/IP connection
Trevor,
If you are fiddling with TCPIP parameters and such, the default values (php.ini) for the following also need turned up.
; Resource Limits ;
max_execution_time = 60 ; Maximum execution time of each script, in seconds
max_input_time = 60 ; Maximum amount of time each script may spend parsing request data
memory_limit = 64M ; Maximum amount of memory a script may consume
In a nutshell, if someone is on dial-up and is running a higher res monitor, it takes the script longer to download the new image than the timeout allows.  I changed the max_execution_time to 180, made a huge difference in stability.  I also set the memory_limit to 256M.
Compressing all of the possible output from the server would help also.
More information about the mapguide-internals mailing list
