[mapguide-internals] missing backward compatibilty of 2.1 server API - feature or defect?
UV uvwild at gmail.com
Thu Apr 23 11:55:02 EDT 2009
DESCRIBEFEATURESCHEMA&VERSION=1.0.0
RESOURCEID=.....
and the parameter count of mapguide studio 2.0.0.3202 is not compatible
to 2.0.2
using 2 instead 3 parms i think.
supposedly the maestro client has been updated....
I am simply questioning  why to break it in the first place......
I believe breaking compatibility in the API between successive versions
is bad practise......
Jason Birch wrote:
> Do you know which specific API call was changed, causing the exception?
> -----Original Message-----
> From: UV
> Sent: April-23-09 8:03 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] missing backward compatibilty of 2.1 server API - feature or defect?
> A recent attempt to verify the map structures used for my test case
> using Mapguide Studio
> an access to a  data resource from within a layer triggered an exception
> in the server.
> (unable to process operation)(Resource ID does not refer to a valid
> feature source)
> This is due to a changed parameter count in the request package.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
