[mapguide-internals] missing backward compatibilty of 2.1 server API - feature or defect?
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Apr 23 12:05:29 EDT 2009
It was changed as part of RFC 53.  I agree - the HTTP request version should have been incremented for the updated APIs.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Thursday, April 23, 2009 11:55 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] missing backward compatibilty of 2.1 server API - feature or defect?
DESCRIBEFEATURESCHEMA&VERSION=1.0.0
RESOURCEID=.....
and the parameter count of mapguide studio 2.0.0.3202 is not compatible
to 2.0.2
using 2 instead 3 parms i think.
supposedly the maestro client has been updated....
I am simply questioning  why to break it in the first place......
I believe breaking compatibility in the API between successive versions
is bad practise......
Jason Birch wrote:
> Do you know which specific API call was changed, causing the exception?
> From: UV
> Sent: April-23-09 8:03 AM
> Subject: [mapguide-internals] missing backward compatibilty of 2.1 server API - feature or defect?
> A recent attempt to verify the map structures used for my test case
> using Mapguide Studio
> an access to a  data resource from within a layer triggered an exception
> in the server.
> (unable to process operation)(Resource ID does not refer to a valid
> feature source)
> This is due to a changed parameter count in the request package.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
