[mapguide-internals] Installer progress
Gunter Becker gunter.becker at csogis.de
Thu Apr 23 17:05:00 EDT 2009
Hi Jason,
yes the service is installed and it didn't start after reboot.
When I try to run the service interactively as an application I get an error
message:
(1272) The coordinate system initialization failed.
(1272) Server stopped.
Gunter
Jason Birch wrote:
> Hi Gunter,
> Did the service get installed at all?  Does it start after a reboot?
> If it doesn't start, what happens when you start an elevated command
> prompt, navigate to MapGuide/Server/Bin and type "mgserver run" to start
> the service interactively?
> Jason
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org
> <mapguide-internals-bounces at lists.osgeo.org>
> To: mapguide-internals at lists.osgeo.org
> <mapguide-internals at lists.osgeo.org>
> Sent: Thu Apr 23 03:30:59 2009
> Subject: Re: [mapguide-internals] Installer progress
> Hi,
> I've tested the installer on Windows Server 2008 and the installer seems
> to
> put everything in the right place (.NET/IIS). IIS 7 integration also seems
> OK (I could open the PHP MapGuide Admin), except that i'm not asked during
> installtion which ApplicationPool to use (like under W2k3).
> Unfortunately the MapGuide Server did not start. I'm not aware if this is
> an
> installer issue or if this is caused by unsufficient privileges.
> On W2K3 installtion works fine like Jason already mentioned. MapGuide
> Server
> process is running.
> Gunter
> Jason Birch wrote:
>> Well, I think I have the IIS7 installer working OK; I still have to test
>> uninstall.  You can see the details here:
>> http://trac.osgeo.org/mapguide/changeset/3834
>> I've uploaded a new installer (that also includes Bruce's FDO connection
>> manager fixes and Walt's rendering enhancements for those who are
>> curious)
>> to the following directory:
>> http://download.osgeo.org/mapguide/testing/
>> -or-
>> ftp://download.osgeo.org/mapguide/testing/
>> I haven't had a chance to test the Apache/Tomcat/IIS6 installers yet, nor
>> on platforms other than W2k8, and it's quite possible that I broke
>> something.  If you have a chance to install and report back on the wiki
>> that would be great, otherwise I'll try to get some testing done on my
>> VMs
>> tomorrow night.
>> http://trac.osgeo.org/mapguide/wiki/InstallerCompatibility
>> Jason
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> http://n2.nabble.com/Installer-progress-tp2675328p2682181.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2686449.html
More information about the mapguide-internals mailing list
