[mapguide-internals] Installer progress
Jason Birch
Jason.Birch at nanaimo.ca
Thu Apr 23 19:21:51 EDT 2009
Well, that's odd. I wonder if the path to CS-Map's dictionaries isn't being set properly.
Is the variable MENTOR_DICTIONARY_PATH set on your system? Is it pointing to the correct location? (C:\Program Files\OSGeo\MapGuide\CS-Map\Dictionaries on standard western install)
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Gunter Becker
Sent: April-23-09 2:05 PM
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] Installer progress
yes the service is installed and it didn't start after reboot.
When I try to run the service interactively as an application I get an error
message:
(1272) The coordinate system initialization failed.
(1272) Server stopped.
More information about the mapguide-internals
