[mapguide-internals] Installer progress
Jackie Ng
jumpinjackie at gmail.com
Fri Apr 24 04:10:32 EDT 2009
Just a thought,
Is it worth having CS-Map by default, install to
[%CSIDL_COMMON_APPDATA%\Autodesk\Geospatial Coordinate Systems] seeing as
that is where the coordinate system catalog tries to find the CS-Map
dictionaries if it couldn't find them in %MENTOR_DICTIONARY_PATH%
Reference:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp#L199
- Jackie
Jason Birch wrote:
> Well, that's odd. I wonder if the path to CS-Map's dictionaries isn't
> being set properly.
> Is the variable MENTOR_DICTIONARY_PATH set on your system? Is it pointing
> to the correct location? (C:\Program
> Files\OSGeo\MapGuide\CS-Map\Dictionaries on standard western install)
> Jason
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Gunter
> Becker
> Sent: April-23-09 2:05 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Installer progress
> yes the service is installed and it didn't start after reboot.
> When I try to run the service interactively as an application I get an
> error
> message:
> (1272) The coordinate system initialization failed.
> (1272) Server stopped.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2691027.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
