[mapguide-internals] Installer progress
alucas
alucas at svl.es
Thu Apr 23 18:48:42 EDT 2009
Sorry,
There is a mistake. Obviously the .fcgi extension cannot point to phpisapi,
point to the mapagent isapi. Reading about this issue, seems that with IIS
5.1 the path needs to acomplish the 8.3 naming convention.
Are you considering this convention?
alucas wrote:
> Ok Jason,
> Forget my last post. I've installed the 0.5 test version and as you say i
> receive the error:
> "The specified module could not be found"
> After investigate some issues, my conclusion is that the problem is about
> the paths for .fcgi and .php extensions in the mapguide virtual directory
> configuration options.
> If I try to specify the path between "", for example in spain:
> "C:\Archivos de programa\OSGeo\MapGuide\Web\Php\phpisapi.dll"
> the problem is not solved.
> But, do this test. Copy all the content from the php directory for exmple
> into c:\tmp (or some directory that you like) and modify in mapguide
> virtual directory (IIS) the configuration of the extensions for .fcgi and
> .php, you need to point for the two extensions to c:\tmp\phpisapi.dll (the
> key is that this path does not have spaces) then the site administrator
> works well for me.
> Thanks.
> Jason Birch wrote:
>> I believe that I installed for IIS+PHP, but the problem is in the ISAPI
>> extensions that get installed regardless of the viewer that is chosen
>> (the MapAgent and PHP ISAPI handlers).
>> Jason
>> -----Original Message-----
>> From: alucas
>> Sent: April-23-09 9:31 AM
>> Subject: Re: [mapguide-internals] Installer progress
>> The problem is for IIS + PHP or IIS+ASP?
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2687721.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
