[mapguide-internals] Installer progress
Jackie Ng jumpinjackie at gmail.com
Fri Apr 24 04:04:17 EDT 2009
I would've thought the IIS admin COM interfaces (used by the installer custom
action) would've automatically converted our paths to 8.3 convention. It
doesn't look like this is the case.
I do recall the MapGuide installation/configuration guide specifically
states that paths to ISAPI extensions must be in 8.3 convention if the full
path has spaces in it (stupid progra~1... ahem! "Program Files" :-) )
- Jackie
alucas wrote:
> Sorry,
> There is a mistake. Obviously the .fcgi extension cannot point to
> phpisapi, point to the mapagent isapi. Reading about this issue, seems
> that with IIS 5.1 the path needs to acomplish the 8.3 naming convention.
> Are you considering this convention?
> alucas wrote:
>> Ok Jason,
>> Forget my last post. I've installed the 0.5 test version and as you say i
>> receive the error:
>> "The specified module could not be found"
>> After investigate some issues, my conclusion is that the problem is about
>> the paths for .fcgi and .php extensions in the mapguide virtual directory
>> configuration options.
>> If I try to specify the path between "", for example in spain:
>> "C:\Archivos de programa\OSGeo\MapGuide\Web\Php\phpisapi.dll"
>> the problem is not solved.
>> But, do this test. Copy all the content from the php directory for exmple
>> into c:\tmp (or some directory that you like) and modify in mapguide
>> virtual directory (IIS) the configuration of the extensions for .fcgi and
>> .php, you need to point for the two extensions to c:\tmp\phpisapi.dll
>> (the key is that this path does not have spaces) then the site
>> administrator works well for me.
>> Thanks.
>> Jason Birch wrote:
>>> I believe that I installed for IIS+PHP, but the problem is in the ISAPI
>>> extensions that get installed regardless of the viewer that is chosen
>>> (the MapAgent and PHP ISAPI handlers).
>>> Jason
>>> -----Original Message-----
>>> From: alucas
>>> Sent: April-23-09 9:31 AM
>>> Subject: Re: [mapguide-internals] Installer progress
>>> The problem is for IIS + PHP or IIS+ASP?
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2690934.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
