[mapguide-internals] Installer progress
alucas
alucas at svl.es
Fri Apr 24 09:16:42 EDT 2009
Hi!,
After installing mapguide I found this error in the server log:
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2009-04-23T20:38:50> 3296
Error: The coordinate system initialization failed.
StackTrace:
- MgServer.open() line 857 file
c:\osgeo\mapguide\server\src\core\Server.cpp
Success: Server stopped.
<2009-04-23T20:41:16> 1820
Success: Server started.
Jackie Ng wrote:
> Just a thought,
> Is it worth having CS-Map by default, install to
> [%CSIDL_COMMON_APPDATA%\Autodesk\Geospatial Coordinate Systems] seeing as
> that is where the coordinate system catalog tries to find the CS-Map
> dictionaries if it couldn't find them in %MENTOR_DICTIONARY_PATH%
> Reference:
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp#L199
> - Jackie
> Jason Birch wrote:
>> Well, that's odd. I wonder if the path to CS-Map's dictionaries isn't
>> being set properly.
>> Is the variable MENTOR_DICTIONARY_PATH set on your system? Is it
>> pointing to the correct location? (C:\Program
>> Files\OSGeo\MapGuide\CS-Map\Dictionaries on standard western install)
>> Jason
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Gunter
>> Becker
>> Sent: April-23-09 2:05 PM
>> To: mapguide-internals at lists.osgeo.org
>> Subject: Re: [mapguide-internals] Installer progress
>> yes the service is installed and it didn't start after reboot.
>> When I try to run the service interactively as an application I get an
>> error
>> message:
>> (1272) The coordinate system initialization failed.
>> (1272) Server stopped.
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Installer-progress-tp2675328p2692408.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
